I want to install a solar panel system to my new home. I want to know which type of solar panel system is beneficial and which solar company's solar panel system will be cheaper and has longer life?
Cheapest Solar Panel System in Perth, WA
You should start out by getting at least 5 cost estimates from installers and get the list of hardware they are proposing. -
Installing a solar panel system is really a big help. I had a solar panel system installed over a year and a half ago by SunSource Group and now have credit (+) $300 on my electricity account. The cheapest system may not necessarily be the best value for money and the most expensive solar gain may be overkill for what you want. At the end of the day you will want a system that is reliable, cost-effective, and will save or even earn you money. To determine which system is best for you, think about: What you are prepared to spend. The amount of appropriate roof space you have available. How much power you want to generate and what you will use. The quality of the components you want used in the solar power installation. The level of service you expect from your installer, including after-sales service. Technicalities you can handle involved in the installation, i.e. โ lead time. Hope this helps
We are always happy to get good information on solar installations but frown on people advertising on this website without first getting approval from the Admin Solar Pete.Comment
Go solar means going green it's good to hear that you are going with solar energy. I have installed solar panel on my roof from freedomsolar.com the company is quite good and provide you solar panel on a very low price. Even when you install solar panel in your home they give you a grantee for a year or it depends on the company's term and condition.Comment
First things first, what city/state do you live in? Some utlities, even planning boards, will fight tooth n nail, not to get you solar you want! Then find dealers/contractors...All the systems are pretty much equal, you still have to go shopping for the 'cheapest' panel/equipment, can't help you there, education is the cheapest route for now...Comment
Are you opposed to installing the panels yourself? The real cost of solar isn't what these solar companies are charging. They are making way too much money off the consumerComment
Paying for a Contractor to perform the work includes the responsibility for them to make the system work correctly. Sort of like buying insurance.
You just have to weigh the price of your ability to install it correctly compared to a licensed Contractor. Sometime a DIY is better. Sometimes not.Comment
You're also paying for labor, overhead and salespeople. I would recommend just hiring an electrician or even finding electrician crews who now install panels. Still saves you thousands. I used to work for a solar company and it's a complete ripoff. Buying your own kit you are just buying the materials and having someone qualified install. I've had a few friends do it this way after the success with my setup.Comment
Sadly here in Florida you have to have not only a certified electrician license but also a Contractor needs to be certified for solar installations. If you live in any community a DIY is off the table.Comment
Will these contractors do an install on a piece rate?Comment
Maybe. They still have to list the installation with the city which then falls under inspection including the required installers certification. It would be hard to not used a fully license installer or a system could be red flagged and never turned on.
It is a mute point for me since I plan on moving in about 1 year. Even if I could get the total price down to $2/watt or less the payback is still over 5 years. My power is < $0.10/kWh so hard to financially justify solar pv.Comment
If anyone knows any electricians in Maryland that will install my 8Kw system I'm purchasing online, please let me know. Solar companies are taking advantage of consumers and I don't plan to use them. Thank you.Comment
If you do find an experienced solar contractor to perform your installation please be careful because the lowest price usually comes with the lowest quality.Comment
FWIW, +1. You get what you pay for, or less. The good feeling of a low price doesn't last anywhere as long as the problems of low quality and lack of professionalism which only get worse with time. The cost of low quality never leaves.Comment
