Soon I will be adding up to a 10 KW solar array to a brand new detached shop I have had built in my backyard. I will be running a 220' trench for my 100Amp direct burial cable within the same trench I will also run my PV cabling and security data cable.
My question is several parts.
First, do I need to separate the different cables within different layers of dirt to minimize any interferences? The trencher can go several feet down if needed.
Second, instead of running 2 very long PV cables from the array to existing invertor would there be any benefit or hindrance of running a single 2 conductor cable (through the same trench)?
Third, instead of running the long PV run to existing invertor (which I will be upgrading to accept larger array) would I benefit in any way by running a second invertor at the array and simply running the AC line to a combiner then back to the grid?
Any help is appreciated, And go
