Ground Mount Wire Protection
Click the image, dunno why it won't attach as a thumbnail
image.jpgComment
Try loading it as an image rather than an attachment. The file is small enough that an inline image rather than a thumbnail should not be a big inconvenience for users.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Attached FilesComment
No HVDC on ground mounts
I prefer using micros on ground mounts so that HV DC isn't an issue. Any layman understands 240VAC and its lethal capabilities and AHJ's are not requiring protection since it's all AC / non hazardous DC.Comment
All electrical power above 50 volts (AC or DC) can be lethal and have caused deaths from electrocution.
The biggest reason experienced electricians have died from electrical shock is because they have become complacent while they are working with something the "understand" but forget how it can reach out and kill.Comment
Safety first
Sorry. That statement indicates to my you have no actual experience or knowledge concerning electricity AC or DC.
Stringing panels together is the biggest risk with HVDC, and using micros, for the most part, eliminates the risk of HV DC exposure ( safety- low voltage can't jump ) since the panels are not in a string.
Research the effects of DC voltage and muscle reaction. Totally different than AC. 600VDC will kill easily, without prejudice.
If someone was to rip a wire from the back of a panel of a string, that conductor can have full system potential.
If the system is outfitted with micro's the most it can have is really 48V, but more likely to be be zero since the invertor would already have shutdown.
It's a risk assessment- avoid what can be avoided. Can't avoid 240VAC+ on a system, but the HVDC can be avoided easily.Comment
To the contrary, well versed. Try BSEE. ( Electrical Engineer ).
As for which type of voltage has more deadly potential is a matter of opinion. I have seen a few ARC flash incidents at 480volts and too many "accidents" concerning low voltage 120VAC that does not make me feel that AC is safer than 600VDC. But your opinion may also be a result of hands on experience.
It still comes down to how the "electrician" is performing their work and what PPE they are wearing to mitigate any shock or flash incident.
Micros inverters have some additional features that make it easier to wire a pv array but also create many more potential failure points. Having a lower voltage (AC or DC) only means to me that it requires bigger and more expensive wiring to reduce voltage drop.
My guess is this will be all mute once the 2014 NEC requirements concerning immediate shutdown withing 10 feet of the array becomes the only type of installation. Hopefully that will make it safer for both the First responders to a fire or someone accidentally adjusting the wiring at the array.Comment
Manufacturers are scrambling to change their hardware to meet the 2014 NEC but most states haven't adopted the 2014 code yet and it could take years to do so.Comment
Is deer barrier enough?
It came from here: www.solarscrim.comComment
This plastic mesh is a bit more substantial than deer barrier.
[ATTACH=CONFIG]7160[/ATTACH]
Just as a heads up, Thom from Spiffy actually does pay for advertising on our sister site www.solar-estimate.org so dont all jump on him for trying to get free advertising, as he does actually contribute financially, cheers all.Comment
Hi All,
Thanks for letting us know. I gave Spiffy a little heads up on another post indicating he needed to talk to you before he advertised. Nice to see it is all good.Comment
Wife is lawyer and son is a drummer
( actually recreational drummer full time wooden boat builder.NABCEP certified Technical Sales Professional
"Q: What do you call someone who likes to hang out with musicians all the time?
A: A drummer."
Mouse over to see the answer.
"It's 95% of the lawyers who give all the rest a bad name. "SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
