Mixing panels with solaredge?
  • DanKegel
    • 2093
    As far as I can tell, when using solaredge, it's safe to mix wildly different panel types in a single string.
    Anyone run into problems doing that?
    I ask because I'm toying with the idea of substuting two gxb300's in a planned array of lg305's to compare them. (Field tests are fun.)
    • 3802
    From SolarEdge techs, mixing modules is zero issue as well as mixing optimizers.
      • 15179
      Probably will not be a problem. Now using a few 100 watt panels mixed in with 300 watt panels may give you some heartburn.
      Let us know the results after you experiment.
      • bridaus
        • Dec 2014
        • 30
        Can you be more specific on this statement? Not that I would do it, or even recommend doing it, but what I understand of the technology so far, there should be no issue with any size. If it meets the optimizer/SolarEdge spec, it should not give heartburn in any way. Don't mean to disagree, just understand.
          Absolutely nothing wrong with 100 W panels as long as the voltage meets the optimizer specs. The SolarEdge inverter cares nothing about what panels are used, it only sees optimizers.
            • 15179
            I didn't realize they even made optimizers for 100 watt panels that had similar output specs or were even compatible with the higher wattage panel/optimizer system.
            If there is hardware like that then my earlier statement is incorrect and heartburn will not happen.
              Think about it like this... even a 300 W panel might produce <100 W for a significant portion of a cloudy day. As long as the voltage is right, the optimizer will adapt to the current. With an MPPT range of 8 - 48 V on the smallest optimizer or 8 - 60 V on the next optimizer size up, most panels will be fine.
              • Panelmal
                • 39
                Just installed one of these systems last week on a bus garage with a lot of exhaust pipes, the inverters are sharp and the install is easy. Would definitely recommend.
                  A 100 watt panel is likely to either be old or be a battery panel with a nominal 12V output. Make sure that the optimizers will work with a voltage as low as the Vmp of your 100W panels, preferably with some margin for voltage drop as the panel heats up.
                    Yes, 12 V panels are fine on SolarEdge optimizers.
                    • solarfrank
                      • 78
                      Just make sure module it is compatible with optimizer and also optimizers are inter-compatible, like P300 with P350 and P400.
                      Inter-compatibility of SolarEdge Power Optimizers
                      http://www.solaredge.com/files/pdfs/...imizers_na.pdf
                      • loobosh
                        • Mar 2015
                        • 40
                        I have a SE7600 with P300 optimizers in a string of 18 285 watts, I have 16 Sanyo HIP 54.8V panels 190 watts that I am not using that I want to add, but need the P400 can I use them two on 1 inverter 2 strings.
                          ButchDeal commented
                          Editing a comment
                          Yes you can add them to the same inverter
