Hey everyone,
I have a few questions about the different wiring of solar panels. And how diodes are used to protect the panels. I would hate to blow one up!
The specifications for the panels I purchased (Solarex MSX-64) are here:
If I want to test a panel a voltage reading is easy enough to take but how do I measure amperage. Can you just connect positive to negative and take a reading or will this damage the panel? Do I need some sort of load between the positive and negative terminals?
I have the general Idea how the diodes work but not how to size them. I have a few simple scenarios below with questions to help me understand the solar wiring better. I appreciate any help you can provide.
If you have 4 12v/5A panels in series you will get 48V/5A.
I understand that bypass diodes are used to protect the solar cells. If a cell becomes shaded the resistance increases. If there is no alternate path for the electricity to go and the voltage is high enough the electricity will force it way through the solar cell heating up the cell and causing failure.
If you have 4 12v/5A panels in parallel you will get 12V/20A.
If you have series string that puts out 48V/5A. Then place it in Parallel with another string that puts out 48V/5A. You should end up with 48V/10A.
- What size diode should be used in a bypass configuration?
- Since these panels are connected in series I assume the diode must be rated to handle at least 48V/5A with maybe slightly higher rating because electricity and components are not exact maybe 10% higher?
- Is there a lot of loss if I use a diode rated at a much higher Voltage?
- Is there a lot of loss if I use a diode rated at a much higher Amperage?
- Will a diode that is rated higher reduce the heat on the component?
- What should a diode be rated for in a blocking configuration?
- Do you need any diodes in this configuration?
- Is there any diode protection so that under certain conditions that one string does not reverse current flow and fry the other string.
- Is there a point where amperage in the system is too high by adding too many series strings of panels in parallel and frys the panels in the system?
- In the example above is 10A flowing through all the panels?
