Ok, a question....
So, I have a 2kW hybrid system installed with 8x240W Sanyo hybrid panels and a sunnyboy 3000 inverter.
The AC SWA cable from the inverter in the attic runs to a seperate CU and meter with breakers before tying into the mains cabling with Henley blocks.
Now, as I am looking at having additional 8 panels fitted to a different elevation (back of house facing SW), I appreciate this will be a seperate string and run through a second inverter.
I have been told that the system, identical to the one already fitted, can be installed and the AC output connected to the same AC cabling as the existing inverter in the loft. Therefore retaining just the one SWA cable running to the Consumer Unit. This would allow the same meter to be used and the same Elios system already fitted, rather than having 2 seperate generation meters and monitoring.
So, my question is how does this work in practice?
My understanding of the way inverters worked was that they sensed the input AC voltage and then raised their output above this voltage in order to export to grid. Assuming 2 inverters are connected, essentially in parallel, I would have assumed that as they are each 'sensing' the input AC voltage that they would end up in a never ending loop of increasing voltage. Ie, the first senses the domestic supply voltage say 220v, then increases to say 225 in order to export to grid. Meanwhile the 2nd inverter is sensing 225v and increases it's output to 230v and so forth and so forth.....
Can someone explain how 2 inverters, each with independent strings work together?
Also, is it reasonable to connect them together in this way?
Thanks in advance.
Thanks in advance.
