I want to feed my subpanel, by running #6 or #8 NM from the main, through the wall a few feet, to the back knockout of a surface mount exterior subpanel mounted on a stucco
wall. If I can't put the clamp screws inside the box, what type of strain relief do you use? I don't want to come out of the bottom into and LB if I don't have to, just to keep it clean. But I also don't want to worry about rain getting behind the panel and down inside it. Also thinking about the rough edge of the stucco abraiding against the wire. Solutions?
