Techies,
I've recently installed an Aurora PVI5000 to a couple of panels. I also have a linux server running which I hooked up to the aurora through its USB interface.
Linux sees and initiates the USB connection. The Aurora has a Texas Instruments TUSB3410 Microcontroller which shows up as the read/writable COM port /dev/ttyUSB0. I use the Linux aurora program to communicate with the inverter via that port.
But, the Aurora inverter refuses to report me anything useful. It connects, but just won't play ball. Until, that is, i hook up a WinXP laptop with Aurora Monitor on it and reset the inverter. Aurora Monitor works as expected, and if I then hook up the inverter with the Linux server (without resetting the inverter) I can get my data there as well.
Then the sun sets, comes up again, and the inverter won't speak to me anymore.
Anyone any idea? Is it a setting at the server? I can't find anything in the inverter settings..
J
Ps
Kernel: Linux Mint running 2.6.32-46-server
kernel module in use: ti_usb_3410_5052
J
Ps
