calculations for Home / Boat / Caravan / Shed
1.Add up the hours that each light will be on for to get the Total of Energy Consumed.
2.From that you can Calculate everything you need IE: Solar Panel / Battery / Charge Controller
My Calculations
3 Zones
1 X LED SPOT @ 10W + 2 x LED FLOOD @ 15W
on for (SEE CHART) hours per night
-Watt/Hour Chart- - Only ever use 12 volt LED lights -
3 Room scenario
kitchen/Diner 15W on when required daily average use -- 3 hours = 45wh
Bedroom 10W on when required daily average use - 2 hours = 20wh
front Room 15W on when required daily average use - 8 hours = 120wh
Total usage per night in Winter = 185wh/d
-Load and Battery -
House Lights Consumption = 185Wh
185 watt-hours divided by 12 volts = 15.42 amphours taken from system in 1 night
Because we can only use half the energy in a lead acid battery without harming the battery,
the minimum battery size is 15.42 amps x 2 = 30.84 amp hours.
I want my system to be reliable if we have four consecutive days of cloudy weather,
4 days of autonomy x 30.84 = 123.36 amp hours for the battery. = 124 + amp hour battery
(Required Battery Bank = 1 x 130 Ah True Deep Cycle
-Charging Battery from Panel-
This installation is in a location that gets 5 hours of full sun per day.
Check the charts for this depending on the month in the Season.
To recharge the battery for one day of use we need 30.84 amps in 5 hours = 30.84 / 5 = 6.17 amps from a 12 volt solar panel array.
-Solar Panel -
Most load calculations include a discount factor for the inefficiency of recharging the battery.
20% is typical. 6.17 / 0.8 = 7.71 amps.
A single 140W solar array that has an Impp (amps maximum power point) of 7.7A would be suitable
-Charge Controller Rating in AMPS-
The 140W solar array has a short circuit amp rating (Isc) of 8.2A 8.2A x 1.25 = 10.25A
use a 10.3A or larger charge controller with this array to charge the battery.
Cheap example - 20A Unit
For best efficiency to charge use an MPPT Type.
- estimated Cost of mentioned Materials - 20 years / $450. = $500./240 months = £2.08 month = .52 per week ....wow
Have seen 140w poly panel on Net for $170 inc delivery
Have seen 130Ah Varta Leisure Battery 12V 130Ah for around $150 inc delivery
20A Charge controller $20 - $60 - mppt prefered of course
3 QUALITY External (For in or out & VERY BRIGHT) LED Lights 2 x 15w/1 x 10w = $60
100m of .75mm twin and earth from wholesalers = $30
Mounting Bracket for Panel = $20
Estimated Total = $500ish
Also required - Fuse box / switches / bits ..
-Solar Panel specification-
STK-140P6-A ...... manufactured by 3E
Related power
140W
Open circuit voltage Voc(V)
23V
Short-circuit current Isc(A)
8.2A
Optimum operation voltage Vmp(V)
18.3V
Optimum operation current Imp(A)
7.7A
Thanks to everyone who places information out there on the WWW
Hope the above can inspire you.
Not mentioned above are Switches, Inverters, Distribution, Heating, Health & Safety,
etc ... Caution -12V Batteries can Cause Fire if not Fused or Stored Correctly-
you may find the 30% discharge rule more convenient !!
Mod note - email removed
My Calculations
3 Zones
3 Room scenario
-Load and Battery -
-Solar Panel -
Related power
140W
23V
8.2A
18.3V
7.7A
