Hey everyone,
Just had my 9 KW solar array installed late last month, and it was approved for use and activated early this month (4th of April). My setup is on a perfect south facing roof with some trees to the East and West that have almost no impact on production. I had my first "perfect" day today with near zero clouds, making a perfect curve from dawn till dusk... with just a bit of clipping in the middle of the day. I have 20 450 watt DC panels on Enphase microinverters rated at 380 watts AC. At first when I was researching prior to purchasing my setup I was concerned about the difference in output between the panels and the inverters, but since most days other than spring and fall when it is cooler and still sunny I will not be peaking above 7.5 KW anyway, I went ahead with this array. From what my research has shown, for my area days like today are about the absolute max I will see. I made a graph of actual production today vs what I would have seen without clipping, then I did the math on how much I "missed out on" from the clipping. I missed out on a whopping 0.6 kWh of production over a 2 hour and 15 min timespan. From what I understand, the additional production "off peak" from the larger panels more than makes up for the small amount I loss from the clipping.
I have included the graph of todays production vs a theoretical setup without any clipping.
Later,
Later,
