Since energizing a new solar system on September 2nd, 2014, I’ve identified several issues with this controller (C150) and am curious if others have noticed these things. Two issues are mostly annoyances but one problem results in unnecessary battery drain and I’ll describe that first.
This is an off-grid, stand-alone system without generator or other back-up system. All power comes from 2.4kW of panels with a 235 Ah, 48V battery bank. The CC150 is paired with a Magnum 4448 PAE Inverter and RC-50 Remote display.
1) Sometimes, there is a significant time lag after a load is added to the system before the C150 adjusts and allows more power from the panels in to cover the load. During that lag, the batteries are carrying a large load even though there is an abundance of solar energy that is not being used. Then, suddenly, the C150 kicks in and the solar power soars and covers all the load and starts recharging the batteries (there is no change in sun availability during this time). I have seen this happen during Bulk, Absorb, and Float modes. Other times it works perfectly. It bothers me that my batteries are put under load and taken well down even though there is more than enough solar energy to handle the loads. Anybody else notice this happen?
2) The “Status” display on the C150 often (some days it’s perfect all day, other times it comes and goes throughout the day) shows incorrectly low values for Wattage and Amperes. For example, the C150 shows 500W at 50V, 10A as the total energy available in the system but the RC-50 monitor indicates the same voltage with batteries charging at 12 or 13A. I have verified with a meter that the RC-50 values are correct. It is especially obvious when the C150 shows 0 watts in the system, yet the batteries are charging and of course there are losses in the inverter as well. If a load kicks in, the C150 displayed values increase but still under report the amount of energy that is being used. This is annoying more than anything. The C150 appears to be diverting power correctly, just not displaying it. Midnite Solar has been responsive even though they say they have never seen this problem before. They sent a new display, which did not correct the problem and now an entire new charge controller they sent does the exact same thing. This indicates to me a widespread quality issue and I am amazed that I am the only one who is experiencing it.
3) A small glitch but I’ll mention it anyway: as you scroll across the maximum power data under the Daily Graph mode (in Logs), the displayed values truncate the thousands so all you can see is the last three digits. I made Midnite Solar aware of this and they said they would fix it in the next Firmware Update.
Any similar experiences with #1 or #2 above would be appreciated. There appears to be no fix for either that I am aware of.
