Yes the outback system is capable of doing this. They call it Grid Zero and is just a setting on their systems.
Most Popular Content
Mostly new to solar and seeking advice
You would be looking for about 24 to 30 of these batteries. They cost around $1100 to $1200 each plus shipping and weigh around 300 pounds each.
rollssurrette_2ks33ps.gifMSEE, PEComment
http://www.businesswire.com/news/hom...d#.VDfjt9R4qUA
Sixfold
You need to do some research to see if your Utility will accept that type of system without having a 7 yr contract even if it is programed not to send power onto the grid but can accept power from it.Comment
--mapmakerob 3524, FM60, ePanel, 4 L16, 4 x 235 watt panelsComment
The diagram for "AC Coupling" for the Outback unit shows power going both ways. From the grid and to the grid. That tells me the hardware can be configured for Net-metering or not. The Utility may want some guarantees that you can't put power back onto "THEIR" grid. If so then working with the Utility may be a safer way to go.Comment
It might not matter and then again if they find that unit connected to the main panel which has the possibility of back-feeding the grid they might get upset and turn off your power.
I'm more of this school of thought. If I'm not feeding into their equipment, they have no say in what I do.
I really like this Radian Series GS8048A. Its a bit pricy but it does alot in that one box. Looks like I could drastically reduce the size of my battery bank.
So:
Grid tie: ~$11k
8kw Solar Array: ~$8k
GS8048A: ~$4.5k
MPPT CC x2: ~$1.1k
Mini 48v battery bank: ~$2k
10kw Diesel Genny: ~$5k
Total ~31.6k + associated wiring and other misc parts.
That's much more in my budget. Although that 11k for the ability to pay for electricity seems like a kick in the teeth.
You would be looking for about 24 to 30 of these batteries.Comment
So:
Grid tie: ~$11k
GS8048A: ~$4.5k
MPPT CC x2: ~$1.1k
48v @ 2430AmpHours would be 116640 WattHours worth of power. Would I really need that much to last me 2 days?!
Using the POCO as your "battery" with a grid tie system will be less costly than using your own battery. If you are concerned about costs and you need emergency power for your home then a battery is the last source you should go to. A properly sized generator will just about always cost less as a back up power source.
Well a 116.6kWh battery system is not really that big if you use 25kWh a day. Most battery systems are designed for 4 to 5 days not 2 days. Over discharging is not good for the batteries and since things happen and with storms and snow you may be without sunshine for a longer period of time. That means running the gen set longer and harder or living in the dark. If you want a smaller battery system then figure on using much less kWh per day and size your battery for 4 to 5 times that daily usage. Or figure replacing those batteries in 2 years instead of the 5 you may get out of them by not abusing them.Comment
If you are totally off grid then it doesn't matter what the POCO thinks or does. But if you connect to "their" grid and can generate your own power then you have to have equipment that will totally isolate your generation from theirs or is compatible and can synchronize with the grid. And that equipment is usually determined by the POCO and not the customer. The reason is for safety regulations that the POCO has to meet no matter how much of an inconvenience it is to the customer.
I think the key here will just be to increase my methods of power generation. Adding wind and micro-hydro to my solar and generator should take some of the strain off the battery bank size.
But you have convinced me that grid tie is the way to go.Comment
But, it's a free country. Pay your money, take your choice.Comment
