  • PositiveEnergy
    • Oct 2013
    • 8
    Hi everyone, this is the beginning of my journey into DIY Solar.
    Hello,
    It is nice to meet you all and be a part of this forum.
    Looking forward to learning a lot on here, I have been learning about alternative energy over the past few years and this forum seems like a great way to learn from more experienced people in the solar community.
    I am planning on building my own solar setup at home, and I will definitely be reading all the great posts on here for insight and advice. My goal is to have it up and running in about a year or less, if my financial situation allows for it.
    I haven't decided if I will be doing an off grid or on grid setup yet, but I am leaning towards off grid for night time use and emergency backup.
    Let me help make that decision right now. You will be doing Grid Tied as you would be a fool to do otherwise if you have commercial power available. If you want emergency back up get a generator.
    Not sure what you mean DIY, but if that means making your own panels forget it. Not going to happen. If you mean install the system yourself is remotely possible, but not a given. Lots of hoops to jump through like certified/stamped plans, drawings by a professional engineer, electrical codes to follow, permits, and inspections to pass. Depending on where you are at your local authority may or may not allow you to self install.
    • PositiveEnergy
      • Oct 2013
      • 8
      Thanks for the input.
      • PositiveEnergy
        • Oct 2013
        • 8
        I thought about getting a grid tie and panels, but the convenience of batteries is too hard to pass up and I think it will be worth the investment. My friend in Cali uses VMAXTANKS SLR155 Solar batteries and he said they're doing great for him, anyone else have experience with these batteries? They are AGM deep cycle.
        Are there certain types of panels better suited to different weather environments? From what I've read a lot of loss of energy can occur from very hot weather. What do i need to know for the cold weather, any advice?
          Investment????
          You can buy electricity from the POCO depending on where you live from 10 to 15 cents per Kwh once a month billing. So if you use the average 1000 Kwh/month about $100 to $150 per month.
          Or you can pay right now today in cash for the batteries for the same power for the next 3 to 5 years in advance around $35,000. In 3 to 5 years pay even more for replacement. You just volunteered to pay 65 to 80 cents per Kwh vs 10 to 15 cents from the POCO
          So what were you saying about an investment?
          Did I mention i twill take another $50,000 in panels, chargers, wire and equipment to go with those batteries? Did I mention you get a new part time job 7 days a week 365 days a year maintaining all that toxic material and a nightmare of EPA paper work keeping track of 9000 pounds of toxic waste from cradle to grave?
          • PositiveEnergy
            • Oct 2013
            • 8
            Investment????
            I will be using batteries w/ mppt and an inverter, I want to be able to run electronics and lights around and inside the house if the power goes out from the company. The batteries are maintenance free also, and it beats having a loud generator running.
            I'm not too worried about the money because I know the value of what I will be buying with regards to my needs. I do however want to spend the money wisely and have a small but very high quality back up energy system.
              The batteries are maintenance free also, Just need routine replacement
              and it beats having a loud generator running. Then buy a quiet generator - they are on the market and common
              I'm not too worried about the money because I know the value of what I will be buying with regards to my needs.o, No, I don't think you do
              That is you choice but hire a engineer to do it or you will end up with an expensive mismatched lot of junk.
              You are talking about a hybrid system - not just your standard MPPT inverter.
              • West Texas Bound
                • Oct 2013
                • 7
                What the ....?
                Investment????
                I bought a pallet of 240 watt Trina solar panels @ .72 c Per watt cost me lil over $3800 and they came with micro inverters . 22 solar panels in all .
                4 panels are hooked up to mppt charge controller keeping 4 100 aph AGM batteries nicley charged ,the other 18 panels are wired to my load distribution box VIA micro inverters If its really sunny my wife can do laundry , vacuuming , and run AC's , when the sun goes down i switch to the batteries ,, for T,V and my whole house is fitted with LED lights . Did I say I haven't paid an electric bill for awhile
                • FloridaSun
                  • Dec 2012
                  • 634
                  No, you said you prepaid your electric bill for a few years.
                  • West Texas Bound
                    • Oct 2013
                    • 7
                    Actually My business went belly up and ended up owing the electric company about 6G's , how bout thum tomatoes , so they threaten to shut me off I said "go right ahead"
                    • FloridaSun
                      • Dec 2012
                      • 634
                      owed 6Gs? ... so $3800 for panels + more for MPPT and AGMs.... that's about 6Gs isn't it?
                      for higher priced electricity....
                      Had a neighbor with the same prob, POCO shut him off for $2+K unpaid bill. He tried winging it with solar for six months before putting the power in his son-in-law's name at a much reduced cost. His wife is much happier now with AC and the pool cleared up.
                        So you expect any of us to believe this? Everyone of us know Grid Tied Inverters cannot work without Grid Power connected. So if you had your electricity disconnected, you would be in the dark and all those M215's you claim to have would shut off until you get grid power reconnected.
                        WASSUP with that?
                        • West Texas Bound
                          • Oct 2013
                          • 7
                          AC coupling
                          WASSUP with that?
                          Education is a good thing my pad wan learner
                            • 15153
                            Since I can't open a power point file on this computer I will presume that it shows the Enphase inveters can be fooled into providing output power without really being connected to the grid.
                            That would require defeating the anti islanding protection circuit which could lead to potential health hazards.
                            It would be safer to have a small packaged nuclear reactor to generate your power.
                            • Naptown
                              • 6880
                              Actually they can be AC coupled.
                              Problem is with battery management and voiding the warranty.
