pump recomend
  • nova
    • Feb 2013
    • 61
    pump recomend
    I want to pump 10' head into 4 solar panels requiring 3 GPM each,
    The panels are built with 1/2" copper I was going to connect them with 3/4 or 1" header, to distribute 12 GPM.
    I would like to go with a solar pump,
    Also need an idea of how many watts panel I would need, I have solid southern exposure.
    but if the dollars are to high for pump and panel, I can go 110Volt.
  • hotwaternow
    • Mar 2013
    pump recomend
    You can additionally try with the other services based mostly on your compatibility here. We offer the simplest service in providing hot water at your door steps no matter the locations limited inside our services. xxxxxxxxxxxxxx
    self serving URL from new member removed. Mod.
    [URL="http://www.hotwaternow.com.au"][/URL]
