solar water pumps 220 volt 1200 watt
+ More Options
Posts
  • alkhaleejsolar
    • Dec 2012
    • 13
    hi,sir,i want a project for water pump,
    i want with out battery and inverter
    i mean,direct 220 to water pump,1200 watt
    so what i need ,how many watt solar panel i need
    and which way to wired,plz explain with detail,
    i want to use only in day ,sun time,
  • Wy_White_Wolf
    • Oct 2011
    • 1179
    If you wish to do this without batteries or inverter you will need to replace the pump motor with a DC unit. What you listed is AC and solar panels produce DC power.
    WWW
    • alkhaleejsolar
      • Dec 2012
      • 13
      what u mean,,???don,t under stand,,u mean,we can not produce AC ,voltage from solar,//plz explain,,
        Better get someone on your team that understands at least a small amount about electricity. Solar PV produces DC power only. An inverter converts that to AC
        • alkhaleejsolar
          • Dec 2012
          • 13
          nice reply from,our dear sir,
          i want to say,that i check a solar panel,back,i remove all diods,
          and now the voltage is ac,its mean,,,when u wired solar cells,it gives ac voltage,but when u put a diode ,its become ,dc,
          so,now i want to say,that,if i remove all diods from panels,,its voltage will be ac,,
          now if i wired 7 panels of 34 volt,in series,34+34.........at leats 238 volt ac,,with out diods,,it will operate any ac project ,for example, selleing fan,its 220 volt and 100 watt..i think
          it will operate.,,,,i think,,,what u say,plz inform,,becoz i am newbie,in solar,,
          i am a mobile phone software and hardware engineer,also i have experience ,electronics,as,tv,,dvd,vcr,,,repairing,
          but in solar ,i am new bie,so plz inform,try2understand
          • Naptown
            • 6880
            Those diodes you removed do not change the panel to an AC panel. They are for bypassing certain strings of cells and are called bypass diodes. Solar cells do not produce AC they only produce DC.
            You have 2 choices here.
            1 obtain a pump that is designed to run on DC and solar in particular (they are made)
            2 Obtain an inverter, charge controller, and batteries sized properly to run what you wish to run.
            There are no shortcuts
              I repeat -
                Can't you build a shutter to open and close 60 x second, to get wild AC out of a PV panel
                • Wy_White_Wolf
                  • Oct 2011
                  • 1179
                  That might give you the top half of a modified sine wave. What are you going to do to get the bottom half?
                  WWW
                  • Naptown
                    • 6880
                    WWW
                    Finish the rest of the inverter
                      First of all, that would be the top half of a pure square wave if the shutter is fast enough. And I prefer to call the next step a modified square wave, not a modified sine wave. --inetdog
                      WWW
                      Just keep thinking outside the box:
                      If you mount two panels back to back on an axle, with the two panels wired with opposite polarity and blocking diodes, then you can just spin the whole array at 3600 RPM and get very close to a true sine wave AC (in current, but not in voltage). Use a smaller fixed DC panel to run the motor. And put the array in a vacuum to reduce air resistance.
                      You have now converted the electrical problem to one that a mechanical engineer can handle.
                      Wait, a further brainstorm: Just make the two panels part of a Savonius type VAWT and they will spin by themselves in a high enough wind.
                        Nah there is an easier way. Wire the panels bi-polar, and install a fan blade above them that alternately shades one panel at a time. A whole lot simpler with a lot less mass to rotate and less complexity.
                          I am glad to see some serious thought going into optimizing this approach.
                          I tend to have wild ideas and neglect the practical aspects sometimes.
                          • ws1530
                            • May 2013
                            AC solar water pump inverter is workable
                            You could use AC solar pump inverter to achieve your purpose.
                            Solar panels: about 3kW.
                            Inverter: 2.2kW, AC 220V output
                            Pump: AC 220V input, no more than 2.2kW.
                            Regarding cable connecting, pls refer to the image.
                            Mod note - advertising is not allowed
                            • deepakpandey2403
                              • May 2013
                              • 12
                              No offence meant but I couldn't stop laughing at this kid.
