Hello,
I have a 1200 liter hour pump operating in a well that is only capable of 950 liter hour.
When used directly with solar panels I limit pump flow by using only the number of panels accordingly to the power needed. That is about 120 watt.
On cloudy days, the problem is that if I run the pump directly from my 48 Volt battery bank, or from 220 VAC generator, the pump logic applies full power to the pump (about 180 watt), the pump runs fine, but dries the well in 15 minutes aprox. Then the pump security switch reacts and stops the pump for five minutes.
I dont want to operate that way, because that means to use the security system as a standard operating system, and I dont like to go that way.
What I am trying to find out is a sort of Dc Dc converter to go from 48 VDC to 120 VDC (voltage in which the pump logic has the maximum efficiency) and limit the power to 120 watt.
I am achieving that scheme, but with poor power efficiency. I work with a PIC controlled converter that drives 2 IGBT, a power transformer with primary winding for 48 + 48 Volt and a secondary of 110 Volt. Then filtering and powering the pump.
I would rather like a switching high frecuency dc - dc converter with power limitation.
Any ideas from similar cases ?
Best Christmas and New Year for all readers !
Horacio
Horacio
