Hi all,
First post here and would appreciate any help.
Have installed a solar powered water pump for outdoor aquaponics setup. The pump feeds water through a number of wall pots into a traditional fountain at the bottom.
Whilst the original description says that the battery has a timer but when it arrived I realised there are only 2 options. 1. Run continuous or 2. Run for 15 minutes every hour.
The problem is that the plants are too wet and don't grow well. I want to alter the timer to run twice a day for example. I haven't pulled the battery box apart as yet - does anyone know the the timer in this battery would operate and whether it could be adjusted easily?
Specifications
Solar Panel:
* Max Power Voltage: 17.28V
* Max Power Current: 1.157A
* Dimension: 52cm x 35cm x 2.3cm
Brushless DC Water Pump:
* Max. Flow Rate: 1400L/H (412.1GPH)
* Pump head: 3.2m(10.5ft)
* Flow adjustable: Yes
* Dry protection: No
* Protection class: IP68
* Cable length: 5M (16.4ft)
LED Light:
* LED quantity: 6pcs
* Light colour: White
* Light photosensitive: Yes
Backup Battery:
* Battery box capacity: 12 – 24V, 4.5Ah
* Power saver timer: Included
* Battery cable length: 5M (16.4ft)
Specifications
Solar Panel:
LED Light:
Backup Battery:
