Low pressure a problem for Shurflo 2088?
  • BryanB
    • Dec 2017
    • 15
    I have a Shurflo 2088 that I want to use to pressurize a water tank. It will have unrestricted water from a cistern but with virtually no psi. Will that be a problem? The Shurflo manual states "If the plumbing is restrictive or the flow rate is very low, the pump may re-pressurize the outlet faster than the fluid is being released causing rapid cycling." I could also potentially put the pump and pressurized tank at a lower elevation where it will have more head and slightly more psi.
  • Wy_White_Wolf
    • Oct 2011
    • 1179
    No pressure between the cistern and pump should not be a problem as long as it unrestricted and the lift is within the pumps specs.
    WWW
      • 15014
      From what you write, seems to me they may be telling you to avoid upstream plumbing designs that would promote pump cavitation.
      Add: More thought = While inadequate pump inlet line sizes can cause cavitation and pressure fluctuations that can, depending on the design, lead to rapid pump cycling, they're probably referring to rapid cycling caused by higher pressure transients from downstream piping design inadequacies such as a combination of small line sizes and long runs/lots of bends, etc. Design problems can happen on either side of a pump.
      • littleharbor
        • Jan 2016
        • 1998
        These pumps are activated by a drop in pressure. They will continue pumping until they reach a pre set pressure. That being said they need to output into a closed system. I would think that using them to fill a tank you would need to be able to manually shut them off. Possibly a float switch could be set up to start/stop the pump.
        • Bala
          • Dec 2010
          • 734
          They do not need pressurised feed but like any pump can only lift so much, the lift spec should be in the pump info.
          The rapid cycling is when it reaches pressure and cuts out via its internal switch. normally about 40psi standard setting.
          Set up your water system, if you have trouble with it rapid cycling when it reaches pressure to cut out then install an accumulator.
          Shurflo make small ones, you can also make your own.
          • BryanB
            • Dec 2017
            • 15
            Thanks everybody for your help!!!
            • Bala
              • Dec 2010
              • 734
              Just a bit more info:
              Pumps need some head pressure ( outlet pressure) to operate correctly, so they can either have an outlet that is smaller than the intake to create pressure in the pump or use the head pressure of the water.
              If a pump does not have a restriction, or head pressure, it can throw the water out faster than it can suck it in causing cavitation.
              The shurflo if a diaphragm pump so they dont matter so much but you still want to keep the outlet to keep the pump full.
              As long as the tank you are pressurising is at the same level or only slightly higher than the pump this will be achieved.
                • 15014
                And a bit more:
                I think you mean inlet pressure, or inlet head, If a pump is operating correctly, it will produce outlet head. Both inlet and outlet head are composed of system pressure, static head (elevation differences ) and velocity head. The head added by a pump in an atmospheric system with no outlet restrictions such as nozzles, valves or piping for example, that will be discharging directly to the atmosphere will be expressed mostly or entirely as velocity head, not pressure. If the discharge is to pressurize a tank, for example, the outlet head will be tank pressure + velocity head plus line pressure drop.
                Cavitation happens when the pressure on a fluid in the pump is less than the vapor pressure of the fluid at it's transit temp. through the pump as a result of the pump characteristics. If the NPSH available is < the NPSH required, some of the fluid in the pump will, in effect, boil (vaporize) and then the vapor "bubbles" will collapse as the pump adds pressure. Cavitation usually sounds like stones or marbles in the pump, or not unlike the sound an Otto cycle ICE makes when it's knocking.
                Relative pipe sizes can be larger or smaller, inlet or outlet, depending on the system requirements. In a well designed system, there is rarely, if ever, any direct relation between those line sizes with respect to cavitation possibilities. As long as the system is designed such that the NPSH, available is > the NPSH, required, the inlet line size relative to the outlet line size doesn't matter, at lest not for cavitation considerations.
                The available inlet pressure, or "net positive suction head, available" (NPSH, available), must be greater than the "net positive suction head, required" (NPSH, required) at the suction port (the inlet) of the pump to prevent cavitation.
                The idea is to have sufficient NPSH, available to avoid cavitation, not necessarily lowering the NPSH, required by throttling the outlet to avoid cavitation. Throttling the outlet will effectively reduce the (absolute) required inlet suction to maybe/probably lower that NPSH, available, enough to stop or prevent cavitation, but that's a poor way to get around a bad design. Correct way is to size and select the correct type of pump for the application and for the flow required, and then design the inlet piping to give an available NPSH that's high enough to prevent cavitation at max. operating NPSH of the pump. Design the outlet piping for max. flow, at allowable pressure drop and fluid mechanical considerations like vibration, flow maldistribution, pipe themmal expansion/contraction and support. Throttle the outlet to control the flow rate, not to prevent cavitation.
                Diaphragm pumps, like all pumps, have NPSH requirements, but because diaphragm pumps are a type of positive displacement pump, the NPSH requirements are usually calculated differently because of what are usually cyclic fluid acceleration characteristics common with positive displacement pumps.
                • Alfredolch
                  • Apr 2021
                  • 3
                  You have a lot of experience, and your answer helped me a lot to solve my problem. I have feeble water pressure in my house, and because of this problem, I have a terrible headache. I tried to solve this problem with my own hands but to no avail. So I decided to call the guys from one of the best plumbing services who cope with blocked drains on northern beaches. They sent me a team of experts who solved all the questions regarding the plumbing needs. I am very grateful to these guys because they saved me from a lot of losses. In addition, they managed to cope with the loss that tormented me for several months in a matter of hours.
                  MOD NOTE: Please do not attach or disguise web links in your post. Do it again and you will be banned.
