We have a full time off grid home with a 500' deep well. Currently we have a soft start Grundfos 5SQ-410 pump that runs at 6.6 gallons per minute into three pressure tanks for a total of 98 pressurize gallons . It takes just over 15 minutes of running to pressurize the house at 30/50# of pressure. The problem is the well pump comes on at night which really hammers our batteries. The current well pump draws 11.2 amps and shows about 2.5 kw while running. I'm thinking of going to a 1000 gallon cistern with a smaller pressure pump so that it can run at night if needed. I will have the solar to use the well pump during the day to pump into the cistern. By the way, our household uses 230-260 gallons of water per day and our elevation is 8,600'. The options I have are as follows: 1)I've found a Grundfos JP05D-CI jet pump that is 1/2 hp and is rated at 3.61 amps at 115v or 7.06 amps at 230v that pumps at 12.5 gallons per minute and uses about 770 watts while running. It is not a soft start pump but will pump up my 98 gallon pressurized tanks in just under 8 minutes which will save some power.
Option 2) is a Grundfos scala2 "on demand" pressure pump that would not need the pressure tanks I currently have in place. It would power up every time you open a water valve or flush a toilet. This pump can be plugged into a 115v outlet and uses 5.7 amps and pumps at a rate of 13 gpm and uses about 550 watts while running. It has a variable smart control that "learns" your plumbing to control speed and power necessary to maintain a pressure you select up to 60#.
There is also the possibility of a 1/2 hp 150' well pump from China that will do the trick of pressurizing my pressure tanks and will just lay down in the cistern. These can be wired either 115v or 230v and pump up to 25gpm.
So, my question is which of these three alternative would offer the least impact on the health of my battery bank? Or do you have a recommendation for a pump or setup that will reduce my battery usage in the evenings?
Thanks for any info you are willing to share.
