I have a 284W solar pump (with built in MPPT), connected to 400 Watts of solar (2 strings of 2 x 100Wp 12Volt panels), according to the manufacturer, it can be operate this way, because it has a wide voltage range and has the controller inbuilt. The specified pump head is 30m, I am pumping from a shallow well to a 3000 L tank (total head is 12m). I switched on the breaker yesterday morning at 10am and it ran perfectly, very powerful water delivery, for about 2 minutes, then turned off, never to turn on again, until today.
When I checked solar array voltage (breaker in OFF position) it is giving me 40Volts (this is within working voltage range of 18-45V), but when I turn on the breaker, voltage immediately drops down to 4Volts. I have checked cabling, connections, debris, but could not find anything.
The only thing i can imagine is I have somehow burnt the motor out, it would be really helpful to have some other ideas from you who may have encountered a similar situation with DC solar pumps.
