Hi, I have bought a Chinese submersible pump and controller which is being shipped now. Its a 3FLS2.3/140-D48/750. The pump is 48 volt and 3 phase I think. It is 750 watt.
It comes with an MPPT controller.
I have 4 X 260 watt. Vmp 31.91v, Imp 8.15Amps
I would like to mount the panels about 50 meters away from the pump where is is an easy accessed flat area and much more sun.
The sales person says I can use 2.5mm cable up to 60 meters but this sounds quite small for that distance. I'm not sure if the MPPT controller will help with the voltage drop or not.
The sales person says the pump will just run a bit slower but doesn't say by how much. I'm pumping water to 90 meters height.
Would be be best to keep the controller close to the pump and extend the solar panel cables?
I think the controller has a maximum input voltage of either 50 or 100 volts.
Thanks,
Thanks,
