I am trying to power a submersible water pump (http://amzn.com/B003Y330W0) using solar panels. Right now the pump is powered 24 hours of the day using a regular 120 volt power outlet. Note: the amazon link says that the pump requires 120 volts, 175 watts, 1.3 amps, 60 Hz but the actual manual (http://manuals.harborfreight.com/man...8999/68418.pdf) says that it requires 120 volts and 2.3 amps, so somewhere closer to 120*2.3 = 276 watts should be needed to power it.
I plan to buy a 45 watt solar panel kit (http://www.harborfreight.com/45-watt...kit-68751.html), a 12 volt battery, and a 400 watt inverter (http://www.harborfreight.com/400-wat...ter-66814.html) to power the pump.
Would I need to buy about 250 watts worth of solar panels (in addition to the existing 45 watts) to keep the pump going during the day? Also, would using a switch (http://amzn.com/B001FRE1E8) be an appropriate way to switch from powering the pump through the solar panels during the day to powering the pump at night through a regular 120 volt power outlet?
Any advice would be greatly appreciated.
