Hello everyone,
I've have a little solar setup to pump water from creek up the hill to water tank:
1) 12DC/10A diaphragm pump rated 160PSI
2) etracer 20A MPPT controller
3) 24V 120W solar panel
4) 20A 12V AGM battery
I've set the controller to switch off at 60% soc and switch on 80% SOC. When the SOC is around 60% and pump is not going I've noticed the controller doesn't send full 120W to battery but just around 50W. So it takes more time to get over 70% but when pump switches on and controller register load, it starts to push full 120W from the panel. As the pump consumes little bit more than the panel produces (this is intentional as I don't want to keep pump running long time) it goes down to 60% in ~2 minutes and switches off again. And the controller again sends only ~50W to battery.
Does anyone have some idea what's going on? Is it because the controller "thinks" the battery is still charged so uses equal/float charge instead of boost or something like that?
I designed the system so it would pump for 2 minutes and then stop for ~1 minute so I don't burn the pump.
BTW the pump should push 5 litres per minute but since I pump around ~80m up hill it delivers only 1.5l/m (which is still fine for me)...
Any advice would be really appreciated!
