solar water pump for watering cows.
At 350 volts you need about 10 ~200 watt panels in series. Each panel has a running voltage of about 34 volts. You would have about $2k just in panels and probably close to that in racking and wiring. -
I would guess that it is mppt and you should be able to do what you're asking. You should contact Franklin and ask them. Please keep this thread updated I would love to know how this gets resolved.Leave a comment:
I have not used a Franklin solar pak but I would guess that they're made for someone like you. Since you already have a three phase motor it should be plug and play.Leave a comment:
So it's a 3 HP pump? Why do you need 3 phase for a 3-HP? Might be better into looking how to swap the 3 phase for single so you can use any conventional generator. Per the Franklin AIM manual you need a 10KW externally regulated or 5KW internally regulated generator to start that pump.
Also, Franklin does make a kit that converts a 3 phase motor into solar. Check these out: http://solar.franklin-electric.com/products.aspx#Tab4. Looks like you've already got the 3-HP three phase motor. Might look into what it would take to get this going. You'll probably save in fuel what it would cost to convert after about 5 years.
Also, it would seem that with a 350V panel configuration I could only have one string. Would it be reasonable to hook up 2 strings of panels at 350V (which could produce up to 16 amps). This would put it outside of the power range on their documentation but it would seem that the controller would only pull the amperage that it could handle. My thinking here is that the extra string would power the pump during cloudy periods.
Does the controller have a buck converter or MPPT capabilities?
ChrisLeave a comment:
VFD - Variable Frequency Drive
You can get a electronic box that converts single phase, to 3-phase and soft start.
article here at Mfg's site
This is likely the easiest route.Leave a comment:
Here is a 5000W 3 Phase Diesel - 240 V 15 amps per phase and your pump by the nameplate is a 3 HP which draws 10.9 Amps per leg full load BUT the Starting amps on that motor are probably closer to 20 AMPs so a 10KW like you have is probably what is needed. Do you know the starting amps using an ammeter?
5000W
The Voltmaster XTP50EL-240 - 5000 Watt Electric Start Professional Diesel Generator(120/240V 3-Phase) XTP50EL-240 has been discontinued. Check out Expert's recommended alternatives for another top portable generators diesel generator.
11000W
https://www.absolutegenerators.com/g...FYyRHwodAMMFuQ
is 208 VAC phase to phase. 3hp is only going to run around 3KW or 1KW per line above, or 8A. A typical
mechanical generator has some surge rating; I wouldn't design for a run rating of the starting surge. The
rotating machinery gives some extra energy. My 8HP 4.5KW generator managed to start up a 4HP air
compressor, yes everything dimmed and slowed but it worked. 2 HP car lift, no problem. Bruce RoeLeave a comment:
5000W
11000W
current system
Deutz 10 kw 3 phase generator running a franklin electric fps 4400 model number 20FA3S4-PE is the current system and the generator just blew up so if it is not practical to run off solar can anybody recommend a good 3 phase generator this size and 3 phaseLeave a comment:
Still gonna have a hard time getting that much water unless you use multiple wells/windmills. I would still go solar on multiple wells. Solar is about 1/2 the cost of wind and much easier to maintain.
Originally posted by SunEagleI had TV in the 50's although there were only 4 channels and all in
black & white on a small round screen.
Today's kids now can't live without their frickin phones for 10 minutes.
missing the pic tube and had continuous tuning (still have it). I learned that good
sound was way more important than the picture. The old time radio guys
understood that, and though the sound was only 1% of the bandwidth, the FCC
enforced using 10% of the transmitting power for sound. The picture had to be
REALLY snowy before you couldn't hear the program. Todays digital guys didn't
get it; the sound drops out all the time.
My second TV had a 7JP4 crt. If you want to call, use my land line. My daughter
eventually bought me an answering machine. Bruce RoeLeave a comment:
Sounds like paradise to me. I only got to visit farms up in NY state when I was much younger otherwise we lived in the suburbs of northmen NJ.---------------------I was lucky I had TV in the 50's although there were only 4 channels and all in black & white on a small round screen. --------------------I look forward to peace and quite when retire and move to my property in northern Florida. Pretty rural up there but I can still go without technology if needed.---------------------Today's kids now can't live without their frickin phones for 10 minutes.Leave a comment:
Lived on a farm until 73 and didn't have TV (in the 60s) and had a 12KW tractor generator when the power went out, to keep the farm running and not lose milk cooling and ventilation for the 2500 chickens laying eggs.Leave a comment:
