Hey everybody I'm new here and need some help. I'm trying to run my pool pump off a solar system. I need help finding out the correct setup I need to power a 220 volt 9.7 amps pump all day every day. Thanks for any help I'm a rookie at this stuff.
Wanting to run my pool pump on solar
How much are you paying per KWH for electricity? You probably can't justify the solar for the pool pump.
Here's a better idea: switch to a 2-speed pool pump and cut your electricity bill in half. On 1/2 speed the pump will pump 1/2 the water but only use 1/8 the electricity. So you have to run your pump longer but still use less electricity to do it.
If you still feel you need to go solar, you install a "Grid Inter-Tie" system, if the Utility in your area allows it. Just panels and inverter, spins your meter backwards daytime, fwd at night. Looking at some big bucks to pay for it, and must get permits, approvals and inspections.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
