Hi Everyone,
Hope someone can advise.
I have 5 55gln drums which I catch rain water in to water my garden and fill a fish pond.
The problem is that some of the drums are a fair distance from the place I wish to use the water, and in one case, is slightly uphill.
I was thinking I could use a 12V 15W DC pump like this http://www.ebay.com/itm/230941130611...84.m1423.l2649
powered by a 12V 15W panel like this http://www.ebay.com/itm/271436895830...84.m1423.l2649
I would use a piece of hose to run from the drum to the intake of the pump, then screw on the garden hose (need an adaptor to go from the 1/2" pipe thread to 3/4" hose thread) on the output of the pump.
and a simple on/off lamp switch between the panel and pump.
Then I would have a light weight portable pumping system to use on which ever drum I wanted.
The pump would not likely run more than 30mins at a time.
Would I need include a Battery Regulator?
