thastinger
that is right.
well, maybe but i need to know what to do next. (suppose it is 10hp)
Yes.
It's an AC pump.
what about batteries?
- Israel.
- all 12 months.
Thanks
1. You're positive there is no way to get grid power to that location for under 100K?
2. You need to go about this from the other direction. If a smaller pump would do the job, it'll be less expensive to buy the proper size pump than to add PV to run the 20HP...assuming the proper size isn't 19HP anyway.
3. does everything need to come from this one well and pump?
your DC pump
run time is going to be limited to the peak sun hours, don't know if that will do the job for you or not but, if not, maybe a couple of smaller pumps running the same time would.
4. Where are you located and what months of the year would this pump be needed?
- all 12 months.
Thanks
