Hey all, it seems the more you read this forum, the more people are trying to get you away from solar
I was thinking of installing a solar pool pump, but reading other threads it may seem better to use a variable speed efficient pump. I have a 10000 gallon pool using a 1HP Hayward UST1102 motor (I think its a hayward max-flo system, i inherited the setup and cant find a model). The pump is on about 2-4 hours a day. That costs me a little under $50 a month at 4 hours. There is also a salt chlorination system.
So whats the way to go? Energy is currently at $0.40 a kWh. Should I investigate a solar based system, or go for a variable speed pump?
regards
cor
regards
cor
