Solar panels of different make behave in weird ways. I hope you'll all agree with me by the end of this thread.
Here's my observation (and I would appreciate if somebody could correct my errors)
1) I have an inverter (off grid, running MPPT) which has been tested around with different make of cells. Its a 2.2kW inverter and i have hooked up a 3kW configuration to it. Now when there is a sudden change in weather (cloud passing by , rains etc) , different responses have been observed with different makes.
a) sudden change in intensity means sudden drop in cell voltage, this will cause the inverter to trip in some case, while in others it gives sufficient time for the algo to work and gradually reduce the voltage(and current) intake (2-3 seconds etc) from the inverter.
Anyone who can put a light on this property of different makes and also a possible solution to make my algo independent of the same.
I would appreciate if somebody could share some good out-of-box solar PV character document/link/ref etc.
Thanks
Thanks
