AC 3 HP Pump
  • Brijesh
    • Feb 2013
    • 11
    AC 3 HP Pump
    Dear Team
    I have installed 3HP AC pump with 41V 150Watt x 28 nos of solar panel. Inveter needs 720V and 7Amp to Start the Pump. 150Watt solar panel gives 4Amp output. Can any one help me do make design for the same.
    Pretty simple but you cannot run that pump with off-grid solar. Well you can run it for a short period of time with 1200 Kg of batteries.
      That con-man selling snake oil has been busy again !
      If you split your array to 2 strings of 18 panels, then wire the 2 strings in parallel, you could get 738V @ 8amps. But you don't have enough panels to do this.
      Additionally, 3 HP converts to 2250 watts. In real life, system losses (20%) and motor losses (15%) will mean that you need to have 3100 PV watts to run the motor. At an absolute minimum. At solar noon.
      Your 28 panels could produce that, but their combined voltage & amps are not suitable. You need 36 of those panels to continue. (Assuming the 41V you listed is the Vmp (VoltageMaxPower) and not Voc)
      Your dealer needs to make this right.
      AND - I know of no inverter that is suitable for this voltage (738VDC) I hope you are not being sold a
      box of junk.
      • Brijesh
        • Feb 2013
        • 11
        box of junk.
        Mike Sir
        Thanks for your detail help..!!
