Solar pump system
  • Eng_Ragy
    • Sep 2012
    • 38
    Solar pump system
    hey guys;
    I would ask for this solar pump system
    In chart 5 KWh/m2/day
    header 12 m flow rate 500 m3/day
    and my location isolation is:
    kWh/m²/day 2.76 3.68 5.04 6.43 7.40 8.04 7.89 7.15 6.01 4.57 3.28 2.64
    For months less than 5KWh/m2/day the pumps stop or the flow rate will just decrease and the months more than 5 KWh/m3/day that mean the pump will
    produce for me 500 m3/ day in 5 hours ??
    Thanks;
  • Naptown
    • 6880
    sounds about right.
    You could also double your array size for the low insolation months.
    • Eng_Ragy
      • Sep 2012
      • 38
      Originally posted by Naptown
      sounds about right.
      Thanks naptown as always you help me .. so increase my array for low insolation months give me 500 m3 / day with header 12m during the year
      the day here mean 5 hours daylight peak ( on grid system ) right ?
      another think form march till September the pump will work only 5 hours in daylight and give me the 500 m3
      Best Regards
      • Eng_Ragy
        • Sep 2012
        • 38
        I would ask if i am right or wrong in this :
        Pumps specification:
        Header: 12 m
        Flow rate : 132 m3/h
        Power: 7.5 KW
        I select:
        Module specification:
        Renesola poly-crystalline 250W
        At NOCT :
        Pm= 185 W
        Vm= 28.2 V
        Im= 6.57 Amp
        Inverter specification:
        SMA Sunny Tripower 8000TL
        Max voltage input = 1000V
        Max input current input A = 15 A
        Output power = 8000 W
        42 panels (14 *3)
        42 *185 = 7770 W
        14 in series
        3 in Parallel
        According to my location:
        Latitude: +31.22 (31°13'12"N)
        Longitude: +29.95 (29°57'00"E)
        will I set my modules 31 degree N ?
        Variable I II III IV V VI VII VIII IX X XI XII
        Insolation, kWh/m²/day 2.76 3.68 5.04 6.43 7.40 8.04 7.89 7.15 6.01 4.57 3.28 2.64
        The flow rate of pump will be
        like this during the year
        364 486 665 849 977 1061 1041 944 793 603 433 348 m3/h
        Thanks;
