There are a few different options that affect the wash time. I go for Eco Cotton as it uses the least water/kg of clothes (probably washes for longer with less water) and you can load the machine with more clothes at one time. There are other options like "Intensive 60" which washes in 60min but then you should only put in 4kg of clothes. But it is definitely possible that your Maytag is better for this application (that brand doesn't seem to exist here).
The main challenge I had in researching this was to know what the Wp would be during a wash cycle. That info doesn't seem to exist anywhere - which makes correctly sizing the inverter difficult. As you know, the kick in Wp of a motor can be 7x the motor wattage for a split second and unfortunately none of the manufacturers seem to have that figure on hand. LG can tell you how many Wh used during the different cycles and also Wp for the spin cycle, but that number seems to be the more constant W consumed during the fast spin and not based on the initial Wp in overcoming inertia. I think most of you have massive 2KW+ inverters so this is less of a concern. Pure sinewave inverters here are pricey so getting the smallest inverter that can handle the job in the long term is important.
The trick now is teaching the mamas at the lodge who can't read or write how to get all the settings right without by mistake doing a hot wash!
