I was looking around the house thinking of an area where I could get my feet wet with solar. Some appliance that uses a decent amount of electricity so there would be some economic benefit, not just a proof of concept.
The best I could come up with was the washing machine. It's 110V @ 8amps. The longest wash cycle on it is about 30 minutes. So I believe that means it requires 440 watt hours.
This would obviously require a battery for storage. I looked at Optima Yellow, rating says 140 minutes of reserve capacity @ 25 amp discharge to 10.5 volts. I believe this is about 300 watt hours for 140 minutes.
Here's where I get lost. Can I compare those watt hour calculations? Can I assume that if the battery can supply 300 WH for 140 minutes, it will be able to do 440 WH for about an hour?
Then I realize I will lose power at the inverter, so that 1 hour will look more like 40 minutes, which should be enough for one wash cycle.
Are my calculations and concepts correct? I'm new to this, please go easy.
Then all I need to figure out is how big of a solar array I'd need to be able to charge that battery in 48 hours or less. At my house I could face the array west or SW. Cleveland OH is the location.
Brian
Brian
