You are 100% correct. Every solar panel is self regulating because they are current sources a point which I do no think you have grasped yet. A typical 100 watt panel made for 12 volt battery systems has a Voc of 22 volts and a Isc of 7 amps.
OK this is where you stepped into a big pile of it and where I think you do not understand what a current source is. The Shell panel you mention for example is a 50 watt panel made with 33 cells. It specifically says to be used on a 12 Volt 100 AH battery with a daily load. Please read it and explain why it is so specific
Here is your clue. A 50 watt panel with 33 cells can only generate 3 amps of current. When applied to a 100 AH battery is a C/33 charge current. If you connected that panel to a 50% discharged battery it would take roughly 5 days to fully recharge the battery assuming the battery had no load on it. That by definition as I explained earlier is a TRICKLE CHARGER. To properly charge that same 12 volt 100 AH battery would require a 160 watt panel with a MPPT charge controller, or a 220 watt panel with a PWM charge controller. To recharge that same battery at 50% would only require 1 day with a light load, not 5 painful days without a load.
Again that is not a self regulating panel. It is just an over priced Marketing Term for a piece of junk. a 5 watt, 12 volt panel generates .3 amps. Car batteries are anywhere from 60 to 100 AH. So a .3 amp current supply is a C/200 to C/333 charge rate. There is no way in Hell that could even possible charge a car battery. A Trickle Charge is around C/100. So that 5 watt panel is not even a TINKLE CHARGER. A 50% discharged 60 AH battery would take roughly 1 month to charge up assuming the battery does not have a self discharge rate. A flooded lead acid battery has a 10%/Month Self Discharge rate. The 5 watt panel can barely keep up with the Self Discharge rate of a 60 AH battery. It is a worthless piece of crap only worth $5. How much did you pay for it?
