Proposed Solar Wireless Surveillance System
First note never ever trust any manufacture where electrical code and safety is involved. Why you ask. Because you got two different answers, they do not know squat about electrical code requirements.A question about fuses and diodes... I asked a Renogy rep if fuses and diodes are necessary for this system using two of their 50W panels and 20A controller, and he claimed that neither is required. However... the Tracer manual indicates fuses for PV input and Battery output. I'd like to get a practical opinion on this.
Thanks,
Roger
A fuse is REQUIRED between the battery and controller, and the fuse must be located on the battery term post to be effective.
MSEE, PEComment
Code requirements are a good point, however this system is developed as a 'portable' system, not attached to the house. It is only driving a 4.5W load (surveillance camera) and the battery and control panel will be in a steel weatherproof enclosure. I guess I can afford the added cost of a couple of fuses for this $1000 "investment".
Thanks,
RogerComment
Fuses are a cheap investment to keep your system safe.Code requirements are a good point, however this system is developed as a 'portable' system, not attached to the house. It is only driving a 4.5W load (surveillance camera) and the battery and control panel will be in a steel weatherproof enclosure. I guess I can afford the added cost of a couple of fuses for this $1000 "investment".
Thanks,
RogerComment
