Solar system design for villages
  • zohaib
    • 37
    Hello,
    I am just started working in solar systems. And i want to design a solar system which would used in villages.
    Actually i want a system used for villages which runs 1 or 2 LED bulb, a dc fan, dc TV and Ac sockets for mobile charging and which will run a bulb and a fan at least all the night on battery. And system have to be affordable for village customers.I want your help in this how can i design this system.
    Wait for your useful suggestions.
  • lkruper
    • 892
    Originally posted by zohaib
    Hello,
    interesting. Is this a single power source that is routed to multiple residences, or individual systems for each resident?
      Welcome.
      First thing, is What is the Load (in Watt Hours) that the system will be designed to?
      Until the load is known, (2KWh, 8KWh, 32Kh) the system could end up being undersized, and fail rapidly, or oversized and cost a lot of extra money - except loads always increase. But you need a place to start.
      try reading the first 4 "stickies" posts here for design assistance, then continue asking questions
      Remember, you are on your way to becoming a Power Plant Engineer, and will HAVE to learn this stuff.
      Discuss remote solar applications for homes, cabins, RV and boats. If you have a question on equipment for an off grid system, such as charge controllers or inverters, then post your question in this forum.
        Until you determine how many watt hours total you need each day, no one can help you. Once you figure that out you need very deep pockets full of money and sky is the limit budget.
        • Living Large
          • 910
          Is this a term that the Bureau of Labor and Statistics uses?
