Electric hot water heated load calculations: Calling the watts and amps gurus
  • Naptown
    • 6880
    Originally posted by hammick
    Checked with the local LP supplier. I can rent a 120lb tank for $50 per year and then propane refills are .99 cents per gallon. They install the tank on concrete blocks and pressure test system. Sounds like the way to go. Thanks for all the advice.
    Buy the tanks
    Renting them locks you into what ever they want to charge. Expect it to go up dramatically.
    But you can only have them filled by them so you pay whatever with no opportunity to shop for less costly propane.
      I almost entered a drawing at our county fair for a free propane tank refill (up to some size limit like 500lb). Then I realized that I could not collect if I won since I do not own my tank.
      On the other hand, the piping service (including switching to two stage regulation when we added a propane dryer) from the LPG vendor was quick competent and well priced.
      • Wy_White_Wolf
        • Oct 2011
        • 1179
        Thanks White Wolf. I'm in Carbon County so we probably have similar PV performance.
        These posts have convinced me to ditch electricity for any heating or cooling uses.
        I grew up in Red Lodge.
        • Wy_White_Wolf
          • Oct 2011
          • 1179
          For propane tanks I'd suggest search for a large tank from a propane powered vehicle or motor home. They're mounted horizontal so less problems hauling them. mount it permanently on a small trailer and you wouldn't have to worry about loading or unloading it.
          WWW
            But you have to make sure you have provisions to ground it whenever it is in use.
