hello! Newb here.
We live in a van with a small 12v pv system which has just stopped working....
I have been trying to figure out what the problem is but I'm totally stumped.
basically the panel is not charging the battery. the system was working perfectly until a few days ago when the battery got a bit over juiced....but the battery still reads 11volts when disconnected, so i dont think it is kaput..
currently the panel is producing about 19volts at the point of entering the regulator. but the output from the regulator to the batteries is only around 4 volts. the regulator seems to be on, but not charging.
i have taken the whole system apart, tested each component and put it back together again... no change.
So is it that the battery is too low? or that the regulator has broken... or something else?
thank you in advance for help or advice
