Independent ( ductless ) Split Air-Cons are common in households. And now there are a new breed of Split Air-Cons called Inverter A/Cs.
These Inverter A/Cs have some additional PCBs, and hardware installed inside them, which reduces the high starting current surge, and also then controls the motor speed in accordance to the room temperature.
I was just thinking, that will it be possible for us that we convert our existing conventional Split Air-Cons to Inverter Air-Con by connecting that special PCB circuit to them ?
Has anyone experimented with any such hardware ? If yes, then please share your findings.
I am attaching herewith pics of some of these PCBs.Inverter Air-Con PCB 1.jpgInverter Air-Con PCB 2.jpg
