solar power for dog house
  • ratcliff23
    • Mar 2015
    • 4
    Hello i am looking for for a solar power kit to power a ClimateRight CR2500 Mini A/C & Heater. Could someone please help me out by telling me what wattage kit I would need. It would be greatly appreciated. Here are some of the specs for the unit:
    Volts115V
    Cooling Watts 480W
    Cooling Amps
    (Startup)7.0ACooling Amps
    (Operating)4.3AHeating Watts 800W
    Heating Amps (Startup)6.9AHeating Amps
    (Operating)6.9ACooling
    Recommended Generator 2000W
    Thanks!!
    You are joking right?
    Well here is the punchline.
    Panel wattage = 4000 watts
    MPPT Charge Controller = 80 amps
    48 Volt Battery Capacity = 1000AH
    Battery Weight = 2880 pounds
    True Sine Wave Inverter = 1000 KVa.
    Rim Shot please for Punch Line.
    Should not cost you a penny more than $15,000 to keep Rin Tin Tin cool and warm.
    • solar pete
      Administrator
      • May 2014
      • 1850
      Volts115V
      Cooling Watts 480W
      Cooling Amps
      Thanks!!
      Hi ratcliff23 and welcome to solar panel talk.
      If your on the grid and so is said dog house look into a grid tied system for the whole house. If your looking to do this stand alone or off grid SK is right you need a large system. Air Con and heaters are the hardest things to take off grid as they draw a lot of power. Cheers and good luck with it
        Sorry ratcliff - No chance - better off to give the dog away.
        • ratcliff23
          • Mar 2015
          • 4
          Oh goodness! Lol. It's a mini ac so no way I thought it was gonna be that expensive. Thanks Sunking!
          Solar pete...I only wanted to put the dog house off-grid. It's just a little project. Transitioning my two" house" pitbulls to outside dogs. I wanted to make them as comfortable as possible while we're away. It's a small unit so there's no way I thought it would be that expensive. They're only going to be out there on the weekends while we're away. That is completely out of the question. I'll do better plugging it into the outside outlet or buying a small generator.
          thanks guys you have been very helpful.
          • ratcliff23
            • Mar 2015
            • 4
            Lol. No chance.
              Well here is the irony. As for power, it does not use very much power for HVAC, less than a dollar a day. Solar is just that expensive. Simple solution though. Run a GFCI AC circuit to Rin Tin Tin's house.
              • ratcliff23
                • Mar 2015
                • 4
                Thanks I'll look into it!!!
