We put up a new woodshed because the old one was getting a bit ratty. The new shed holds 24 cords of firewood - plenty to get us thru a tough winter. I been processing and delivering firewood to my other customers - 700 cord in the last month. So I only got our shed about 1/3 full right now, but I'll finish filling it this week.
Gotta have lights in the woodshed. Always used a flashlight in the old one, which was a PITA in the middle of winter. And I'm not about to bury power to this shed from the next closest building when all that is needed in there is decent lighting to load the wheelbarrow at night and split some of the bigger chunks that the wood processor let slip thru.
So I dug around in the shop to see what I had to put in a standalone off-grid lighting system in the new shed. I found a Everstart 14ah motorcycle battery that was badly sulfated and only had 11.53 volts in it. So I put that on the charger for the last week and EQ'd it for 5 days. It finally came back to full capacity on a load test after 60 hours of EQ charge at 15.5 volts. I found two Attwood marine LED's in a box - perfect for lighting in there. And I found a VW solar panel that has the plug thing gone off it that used to plug into the cigarette lighter in the car. Volkswagen put these solar panels on cars that were shipped to the US to prevent the battery from going dead, and IIRC they're like 11-12 watts or something like that. It puts out 22 Voc and about 800 mA @ 12.5 volts. The lights draw 700 mA and light it up bright as day in there at night.
It all works - battery with a toggle switch taped to the top of it. I ran the lights for 3 hours last night to draw the battery down a bit and the solar panel already has it up to 13.5 volts today on bulk charge. I know from previous experience with this solar panel, using it as a maintainer on my diesel genset battery, that it will not get the battery much above 15.0 volts on a perfect day.
All the wiring is fully off-grid approved - as in whatever you can find laying around the shop to make it work. The only thing I have to buy is a 1A fuse for it, which I couldn't find in any of my boxes of stuff.
