You can hit all those goals except "inexpensive." Again, going to a very efficient A/C (a mini-split) will be the best first step in getting close to your goal.
The "DIY knowledge" is troubling, though. You can certainly DIY. But if you are worried about installing a mini-split - which after all comes with detailed instructions, mounting templates, on line support etc - then building the kind of solar system you describe is going to be ten times harder. There won't be any instructions or manuals or videos showing you exactly what to do, and you'll still have to do all the drilling, venting, pulling wire etc that either project entails.
Solar powered AC air conditioning, a bummer or a challenge?
Not in your wildest dream Raymond. All the mentioned battery manufacture cycle life chart follow the same cycle life curve. There is a direct relationship between DOD and cycle life. The real answer is the battery warranty. Trojan RE line is 24/60 exact same as Rolls 4000 Series. That means a 5 year battery period. Abuse them by more than 20% in hot conditions you will get much less.
Trojan Cycle Life Chart
Abe (several generations of Raymond's so most of us go by our middle names, mine is Abraham)Leave a comment:
This sounds very doable to me if you are frugal where you shop, The room is well insulated and on the north side of the building with double or triple pane glass in vinyl frames. The main problem I see would be the same with the refrigerator door if there are frequent trips to the bathroom , the kitchen, and kids fanning the door, this probably won't work. But for a retreat to take a nap out of the heat it sounds like an excellent idea.
I hit garage sales during the winter in Oregon and buy AC units for $10 to $30 each. then take three to five of them each time I go to Texas to use in the rentals. Two of them in the last few trips have been 5500 BTU Using only 480 watt. They do not drain the water it stores in a pan and the fan picks it up and throws it into the condenser to cool it. I only bring this up to point out if you are not getting over 10 BTU's per watt it may be more cost effective to use a more efficient AC.
Abe
You're getting better but I need some Good stuff to get on your wavelength.Leave a comment:
AbeLeave a comment:
Geez. I feel like I'm repeating things so I'll repeat my goals expectations from the beginning and I'll even give $ figures this time.
Budget
Inexpensive but capable solar array <$1000
Inexpensive but capable inverter and charge controller<$300
Inexpensive battery bank <$1000 (I can bend more on this for the right thing)
660 watt 120VAC air conditioner
My expectations to prove this model sustainable:
-This system would work just the air conditioner in a well-insulated 25x11' off-grid home addition.
(The 12v electrical outlets and lights would all be working off a separate, smaller, 12volt system.)
-The air conditioner should run estimated 5-7 hours per day for 150-200 days a year.
-The larger array and battery bank will not be in use the other 6 months of the year.
-Batteries should last for at least a couple years.
I have constantly been told by naysayers in my city and state and people who've expressed no interest in investigating the matter that it's pointless and can't be done without an extreme startup cost and pricey components.
My ONLY goal is to prove first that off-grid Air conditioning is sustainable in the Deep South with only inexpensive components, DIY knowledge, good insulation, and conscientiousness. If it can be done, I can change the thinking around here one person at a time, and perhaps apply the principles into a future home later in life.
If it can't be done, then I can probably still build the home addition with more conventional methods.
I don't have anything against the power company. I am aware the cost of power will be higher than a regular home addition with the new electrical added. I have no interest at this time for grid-tie or conventional methods. I would gladly investigate them only if I admitted defeat first.
I believe this can be done. But I'm not certain. This is the only reason I've joined the forum.
AbeLeave a comment:
Then i would say, just quit now. Any neophyte trying a MAJOR project, is going to make mistakes. YOU open the fridge 3x a day. But the cat gets in there 7x a day and there goes your power budget, along the the primo brand batteries. If you leave the porch light on one night because you were sick and forgot.... Mistakes happen, and you need to design your system to be resilient enough to not die from the first one.Leave a comment:
I will reiterate
Budget
I believe this can be done. But I'm not certain. This is the only reason I've joined the forum.Leave a comment:
Not the case for any of them. Stationary Batteries for Telco are designed like a starting battery and discharged at C/4 and higher. They are used for emergency stand by only which is rare. When commercial power goes out, the generator starts and takes over within minutes. If the genny fails to start the site will crash in an hour or less from over heating even if it is -40 below zero outside. Built thousand of telephone office and cell site plants. Press those batteries into cycle service and you wil only get a couple hundred of cycles out of them
Yep built a few hundred of them. Most usually have 10 day reserve capacity and over sized panels plus generator. However they do not use batteries I speak of here on the forum. They are industrial grade. Not so sure if salvaged or replaced batteries would be a good idea as they will have already had 10 years of cycle service on them, or failed in service. They are only warranted for 10 years.
Here is a nasty secret folks should know. Utility batteries are large and require EPA permits to trace then from Cradle to Grave. It cost utilities a lot of money to remove them, store, and dispose of them. To make up from some of those losses, and more importantly relieve them of the EPA liability and fines, is they find a sucker to buy them. Once you sign those papers, it i snow your problem and liability. If there is a spill, fire, or accident with them, you wil be held responsible. Dump them illegally, they will trace them back to you and hold you accountable for the clean up and heavy fines plus any criminal charges locals will hit you with. .
AbeLeave a comment:
Hey Sunking, I really mean types of batteries not brands. I really have no knowledge at all about the subject, only that AGM is supposedly very good and low on maintenance.
Abe I've said this before, but I don't mind saying one more time. It's the individual components that I'd like to keep down in cost. For instance, a 24VDC 12,000 BTU air conditioner would be at least $1700.00 (<-- the only one I found with a price tag on it). Or a solar array professionally installed for $10k. A few batteries for a couple hundred each is not an extreme cost. The first question on this thread was is it viable to have a sustainable working system that won't break the bank when one of the individual components fail.
Many hundreds of professionally installed solar panels Near Palm Springs and desert palms were recently picked up and thrown around in the wind. They were sold for the scrap aluminum frames. I choose to make my own mounts and mount my own. Mounts I use in mild Oregon weather are much different than the mounts I use in hurricane alley East Texas. Solar trackers are a consideration in Oregon but have proven to be unsuccessful in Texas.
AbeLeave a comment:
