Does the following setup makes sense?
The installation is 100% off grid. 230v single fase.
40kw solar panels
300kwh battery pack
45kva diesel generator
Four Sunny MC to the panels and load
Three Sunny Islands to the batteries, generator and load.
Location is Bali, Indonesia
Max load from 9:30 until 2:30pm is 14 kw (all pumps running etc.)
Max load all other times is 10 kw
24 hour period use is 140kw/h
But 10 days a year the maximum load will be 30 kw, this is where the generator is needed. Obviously the Sunny Islands don't have enough power, so generator autostarts when the load is to high (and when battery charge is too low.)
I know this system is undersized, but I don't mind having the diesel genset running once in a while
Many thanks, Sunny
40kw solar panels
300kwh battery pack
Many thanks, Sunny
