Here is my setup located in southern India:
1. Four 250W 24 volt panels in parallel
2. Phocos CXN 40 charge controller
3. 8 Batteries 24 volts total (four 12V 100 amp-hour in parallel in series with four more 12V 100 amp-hour in parallel)
4. Single 220V Inverter that is offgrid
Here are my results:
1. Get about 32Volt open circuit
2. Get about 28Volt with load (connected to battery bank)
3. Maximum instantaneous current ever collected is 28 amps
4. Maximum panel teperature is about 105 degrees Fahrenheit
Usage:
1. Adjust panels every month and now (November) at 20 degrees off zenith
2. Dust off the panels from any bird dropings and dust every morning
3. Check batteries for distilled water level
4. Use power from solar for the all of the lights and ceiling fans and computers
5. Use solar power from 8AM till the battery bank reaches 30% charge left (around 8PM)
Questions:
1. Am I getting enough power from my current setup?
2. If I am not getting enough how can I maximize my investment?
3. What is the proper way to use my battery bank to maximize long life of the batteries
I would greatly appreciate your advice and suggesions.
Usage:
Questions:
