What would one expect the voltage to be for a 12V panel in full sun connected directly to a 12V battery?
I am having a boatload of problems with my solar project. Here is what it looks like: P1110342.jpgP1110347.jpgP1110353.jpgP1110358.jpg
It is a 5W BP panel connected to a Morningstar Sunsaver-6L charge controller connected to a 5Ah sealed lead acid battery, supplying power to a 12V car cigarette lighter to USB adapter, to an Android phone. I wrote Android software to be able to send back remote photos to any other phone.
I have already had one system out in the field for months. It works like a charm. Although I will admit that on that one I used a 10W panel with a 7Ah battery.
I have had problems with this one since the moment I put it together. The first morning I came outside, I had all sorts of critical errors on the charge controller, the battery was close to flat and the panel wasn't charging the battery. Since then I have focused on the panel because I can't get more than 12.4 volts out of it. This happens to be less than the low voltage reconnect on the charge controller, so it is never going to start charging the battery in the morning.
The panel is a BP Amaresco AMS-SX405M (http://www.mrsolar.com/pdf/Ameresco/Ameresco%20405M.pdf). I took readings this morning. The open voltage is 22V. The short circuit current is 280mA. I bought a brand new car battery yesterday. The voltage on the car battery is 12.6V. When I connect the panel directly to the battery, it is still 12.6V. The current running to the battery is 300mA.
Before I go and get another panel, I'd like some advice on whether the voltage is too low. I would have thought 14V better. I do recall the 10W panel being around 13.3V when charging. I bought a small electroncs charger yesterday to see if there was a problem with my 5Ah battery, but it charged up in a couple of hours, starting at 1.4A and trickling down to 100mA.
