So You Want To Go Off-Grid Battery
This is a sticky topic.
    So you want to go Off-Grid with a Stand Alone Battery system to save money at stick it to the man huh? I understand but do you know one simple fact batteries need replaced about every 5 years on average?
    So you are typical John Doe who uses 30 Kwh per day and pays the Mean Ole Greedy Power Company (POCO) $100 to $120 per month to make the Greedy SOB's at the POCO filthy rich.
    Well here is a FACT to start with to help you decide. It will take a 10,000 pound, $23,000 dollar battery to make it work that needs replaced every 5 years or so depending on the amount of daily care you give it. The battery will be more expensive 5 years down the road when it is time to replace it. That is just for the battery alone. No shipping cost or all the other $25,000 to $50,000 of additional equipment you will need to pull it off.
    Now compare the battery cost alone @ $23,000 for 5 years vs up to $7200 on the high end to the mean ole POCO for the same amount of power in 5 years.
    So who gets it stuck up there you know what going off-grid if you have a choice?
    Hope that helps.
    Edit Note:
    I can hear the Green Mafia crying right now faced with facts.
