Hi there, please be gentle with me as I am new to the forum!!
I have just purchased a 200W solar panel from Ebay.The label says VWP 18v and current is 11.1A. By my calculation Watts- 18x11.1= ~200W.
Unpackaged the panel and took outside to the yard to test under bright sun early afternoon.
Measured Open Circuit Voltage and Short Circuit Current using the trusty multimeter and got following results:
V=35.7
A=7.0
W= ~250W
This was measured directly across output cables with NO regulator.
I then spoke to the company as obviously panel was 24v. They said oops, maybe the junction box wired wrong. The junction box is connected as below.
They asked me to connect a wire between the 3rd and 4th connection as per below.
I then tested this and got following:
V=23
A=6
W=138
The connecting wire seems to have corrected the voltage to within acceptable range for 12v regulator, but the amps should be around 8.3A going by 200/23=8.7A.
I would still expect the Watts to be higher than 200W when calculting open voltage and short circuit current.
Any advice would be greatly appreciated as the supplier is dragging heals and I am off camping in 2 weeks!!
Cheers.
V=35.7
A=7.0
W= ~250W
V=23
A=6
W=138
Cheers.
