Amazon.com has a pretty good deal on a PWM and panel for $309.00. Ships free and I believe no sales tax.
Need to power 320 watts for about 10 minutes a day....
http://www.amazon.com/HQRP-Monocryst...997966&sr=8-58
Regardless of which panel I choose, I'll have that panel, the SS-10L charge controller and voltage monitor for about $225 shipped.
Anybody got anything good/bad to say about the panel brands I mentioned?Comment
Well, here's what I ended up with--
1) 80 watt Solar Cynergy panel-- $169 shipped
1) Morningstar SS-10L charge controller--$47.90 shipped
1) Blue LCD voltage monitor-- $4.69 shipped
1) Xantrex Prowatt SW600 true sinewave invertor-- $155.68 shipped
1) Xantrex remote on/off switch for invertor-- $28.99
total of $406.26
I could have went with a cheaper invertor, but I've had my fill of the cheap ones in my toyhauler. They never seem to last. I also wanted to be sure my power supply was clean so I don't have ballast issues with my T8 lights.
The Solar Cynergy panel seemed to have good reviews on the newest versions and it was also the least expensive, so I went that route. The SS-10L, just because it seemed to do what I needed for a decent price. The LCD monitor is so I can check battery voltage easily anytime I want. I'll be running it off a switch so it will have little effect unless I need it.
I'll be using 2) walmart 12v deep cycle batteries from my toyhauler, so no extra charge for those. I only use the toyhauler maybe twice a year, so it won't be inconvenient to swap the batteries back and forth as needed. I think it'll actually keep the batteries in better shape than now.
I think all in all..... it's some decent equipment for not a ton of $$. Time will tell, but it's a great start to learn with.
Just gotta make the mount for the panel and wire everything up and see how it does!! Thanks for the help!!Comment
Great, and you will be switching the dc to the inverter on and off, so the inverter idle raw does not drain the batteries ?
Get a good 12V DC switch, maybe from a good autoparts store, Household AC switches will fail quickly with high amp DC going thru them.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
prowatt-sw-remote.jpgComment
Switch ordered...add another $28.99 to the total. I could get away with something simpler...but this one is nice and all ready to just plug in.Comment
I'm going to mount the switch right next to the light switch so it's simple to use.Comment
I'm suggesting for the OP, that he needs a way to shut off the inverter, and it's idle losses the other 23.5 hours of the day, I'll trust him to turn the 120VAC lights off and on.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
First one I googled. But I've seen the prices as low as $30.
