I have a 10'x12' shed, with a glass door and two windows, and 194 sqft of root at a 2/12 slant (it's a bit bigger than the size of the shed).
I want to run air conditioning in there (min-split like this), as well as a few screens, wifi router, my computer, lights, etc. The AC in the link has 1080W rating, with max of 1340W (see https://images.thdstatic.com/catalog...518b0f0c53.pdf).
I've done research on other websites, and came to a conclusion that what I need is:
* 8x320W panels (that's what the roof of the shed can fit), like these: renogy.com/320-watt-monocrystalline-solar-panel (NOTE: my shed's roof is facing north, at a 2/12 slant, my latitude is 38 degrees north)
* A 3500W 48v inverter/charger: https://www.renogy.com/48v-3500w-sol...erter-charger/
* Four batteries to get to 48v at the required amps: https://www.renogy.com/deep-cycle-ag...12-volt-200ah/
Obviously, on days where there's little sun, I won't be able to run the A/C, but then again - I won't need it
(other than really cold days where I'd like to heat up the place, that's an issue I haven't solved yet)
Is my design making sense? Will this work?
What am I missing here?
