Ok Im back. So here is a brief synopsis of what your looking at.
Sketch A is the "Current Configuration"
Sketch B is the "Proposed Configuration A" which if installed correctly would require some amazing welding, but let me tell you guys, the welder I know is a Picasso with a welding stick. He could do it. It would require a 1X1 cage to be extended close to 3 feet off the back of the roof to accommodate the massive overhang of these panels. Also this configuration would mean permanent reduced clearance on the top rear of the trailer. The configuration would allow me to have 3 X 325 Watts = 975 watts total collected radiance (obviously the total input to the system would be less and not always at optimal position to the sun, see I AM learning!!!!!) but it would be a lot of weight on the back side of the trailer. I am not worried about the roof, my welder built those beams to take 2000 pounds or more, so I just need to imagine the three panels with the overhang. In the rain it would make a good awning
Sketch C is the "Proposed Configuration B" which although is less dangerous structurally, not by much. Also I would only be able to run 2 X 325 Watt = 650 watts total collected radiance, and to build a system like that would take some engineering. Keep in mind the entire tiny home was built with custom engineering, so like my welder always says "if you can dream it, we can weld it".
anyway I do realize that depending on an audit, which has yet to be done, and possibly changing out inverters and batteries, this may not wholly be necessary, I just wanted you guys to see my ideas so far!
Comments welcome!
Comments welcome!
